Will not start
160,000 MILES • 3.0L • 6 CYL • 2WD • MANUAL
ANDREW LLOYD
the truck was running fine, until i was driving one day made a turn gave it gas and it just shut off. i replaced the fuel pump and that didn't fix it. then i checked for spark and no spark. replaced coil and it still wont start. What do you think it might be? What should i check now?
Jun 5, 2019 at 7:28 AM
JOETECHPRO
  • 705 POSTS
Hey ANDREW LLOYD,
Just to be sure i have attached the process for checking for spark below.
If you have verified that you have no spark there are few things to try, starting with checking fuses.
I will run you through fuses and points to check for battery voltage below.
This system has a separate ignition control module as well as the ignition coil and the PCM.
Regards, Joe
Jun 6, 2019 at 2:23 AM
ANDREW LLOYD
I have already checked for spark.
What do I need to check next?
Jun 6, 2019 at 2:34 AM
JOETECHPRO
  • 705 POSTS
Hey Andrew Lloyd,
I have attached the engine controls wiring diagram below.
Things to check first would be that fuse 4 (30A) in the under hood fuse box is in tact and has 12V at both sides.
I would also check all other fuses in the under hood fuse board as a precaution while you're there.
Guide to check fuse below:
https://my.alldata.com/repair/#/repair/article/40986/component/323/itype/32/nonstandard//selfRefLink/true
Also check battery connections and engine ground wires to ensure nothing is loose.
If this is okay the next thing i would do is to remove the distributor cap and check the condition of the cap and rotor contacts. Make sure the rotor is seated correctly and the cap is fitted correctly.
Check the connections of all of the plug wires and the lead from the ignition control module to the center of the distributor.
Check connections on the Ignition control module (ICM) and Power train control module (PCM).
The ICM is mounted to the to the radiator support, left front of engine compartment.
PCM left rear corner of engine compartment.
If all connections appear okay and you have power at the fuse you will need to check for voltage at the ignition coil and at the ICM.
Do you have access to a multi-meter or test light?
Regards, Joe
Jun 6, 2019 at 2:43 AM
ANDREW LLOYD
yes i do. could it be the crank position sensor? but i will check these other items first and will let you know.
Jun 6, 2019 at 2:55 AM
ANDREW LLOYD
it was the rotor on the distributor, it came apart. going to change both rotor and cap. thanks for all the help!
Jun 6, 2019 at 5:36 AM
  • 55,746 POSTS
JOETECHPRO is one of out best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Jun 8, 2019 at 9:11 AM
BELETTE
I drive a lot of short stop-and-go trips. Recently, after 3-4 trips, the hot engine will turn over but not start. Usually, after waiting 20-40 minutes the engine will start. The same problem occurred about 12 years ago when the vehicle was still under warranty and most of the ignition system was replaced. The problem has occurred a few times in the intervening years but now is occurring more often.
Jun 8, 2019 at 9:12 AM (Merged)
  • 75,988 POSTS
Go to this link: https://www.2carpros.com/articles/car-cranks-but-wont-start
  • 75,988 POSTS
Hot or Cold engine
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
JOSE MARTY
it was running yesterday. today i went to start will not start. it cranks and have spark. Spark plugs and wires are new. you can hear the fuel pump. i check the timing is okay.
  • 55,746 POSTS
It sounds like you may have lost the timing belt. Can you check the compression for me, here is a guide that will show you how.
and
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
JOSE MARTY
i put new fuel pump new fuel filter new fuel pressure regulator dont start
  • 55,746 POSTS
How was the compression? Im wondering if you have a broken timing chain or belt that why I ask.
SAUSTIN1958
We were having the truck intermittent stranding us just running fine then goes dead like you run outta had after waiting 30 minutes started back up and drove like nothing happened it did this approx 10 times over 1 month now it started start fine idle fine pull outta driveway get 2 houses down and the truck violent bucks and jerks on accel replacefThrottoe sensor messed with idle air solenoid screw at plug messed it up basically put an aftermarket one on off a 92 I guess it will crank but not run I have been able to get it run twice with me working throttle wife's starting reach approx 3000 rpm dies has new fuel pumpkin tps fuel filter cleaned mass air sensor using mass cleaner also replaced inlet air temp sensor in air box tired of guessing to expensive 94 Mazda b3000 EFI distributor also forgot plugs wires ignition coil all parts were replaced b4 she took a dump please help thanks Steve
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge first auto parts rent it. see link
MARK KINSEY
The battery in my truck was dead for a couple of months. It was running fine befor I let the battery die. I just put in a new battery and it won't start. I don't think it is getting any fuel. I've read there is a reset button for the fuel pump. If there is where is it and do you think this is the problem. It turns over fine but dose not start. Thanks Mark...
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_ifs_1.jpg
If not-Lets do below for a start to determine if its fuel or spark related issue and get back asap. Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
