Wont Start New Parts
MRSNITA
  • 1989 FORD
  • 89,000 MILES
Last Thursday about 6:00 van starter kept turning over, I turned the ignition off instantly and it kept turning until it turned off by itself. Cranked ignition up again and it cranked normal but the entire drive of all about 6-8 miles heard clicking until I shut engine off once arrived at destination. An hour and half later tried to start vehicle and the starter once again kept turning over and I turned the ignition off again and it stopped on its own, but tried to start it back up and nothing, it completely died. Had new battery installed, new starter installed, also new fuses as well as solenoid switch was changed to new. Still nothing got some power tried to jump but nothing still. Was told it could be the ignition module so changed that and still wont crank. Please help been sitting broken down for a week and a day.
Friday, February 19th, 2016 AT 11:29 AM
WRENCHTECH
  • 20,761 POSTS
I would suspect the starter solenoid on the firewall. Double check all body grounds. I had one do that one time and it was a broken ground strap.
Friday, February 19th, 2016 AT 3:09 PM
MRSNITA
Okay how do I check for that? And Thank you very much for your response.
Friday, February 19th, 2016 AT 3:51 PM
WRENCHTECH
  • 20,761 POSTS
The small wire on the "S" terminal is the trigger wire so it should only have power when the key is held in "start" position. If it won't stop cranking pull that wire off and see if it stops then. If you don't have power getting to that wire, start checking all your fusible links which are connected the the battery side of that solenoid. Pull on each wire and if any of them stretch, they are burnt out. Use ONLY FUSE WIRE to repair that.
Friday, February 19th, 2016 AT 4:00 PM
MRSNITA
Okay thank you so much I will give this a try in the morning. If I have any other questions can I contact you for assistance? I really appreciate your help. Have a great weekend!
Friday, February 19th, 2016 AT 5:35 PM
WRENCHTECH
  • 20,761 POSTS
Just post any follow ups here
Friday, February 19th, 2016 AT 5:37 PM
MRSNITA
Okay will do, thanks and have a great night/day
Friday, February 19th, 2016 AT 6:48 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,413 POSTS
I have seen where the battery is too weak to disengage the starter once it has begun cranking over, have you tried a new battery?
Monday, March 7th, 2016 AT 2:46 PM
