Will not start but turns over
2,000 MILES
BROSIA
Hi. Okay, so I have to explain how it got to this point to see if it’s messed up anywhere. The serpentine belt fell off due to the belt being messed up before I got it. Then the tensioner broke so I had to get that fixed as well. Had to put new radiator fluid in it. Then put a new belt on. Now a new battery. And now it won’t start. I can get it to turn over but it won’t fully start. I don’t know if something happened in between the times they were fixed. But I really want to know so I can fix the problem myself. If anyone can help me in some way that would be great. thank you.
Oct 27, 2019 at 7:10 PM
  • 110,251 POSTS
Welcome to 2CarPros.
Did the vehicle start since the serpentine belt broke? If not, I suspect the crankshaft position sensor wiring may have been damaged by the belt.
Here is a link that explains the most common causes of a crank no start condition. Take a look through the link and see if anything helps.
I will watch for your reply.
Oct 28, 2019 at 12:13 PM
