I thought I should add, it has a high rise intake as well as a knock off Holley carburetor unsure of size it is either a 600 or 650. It has flat top pistons, the original 64cc heads, factory cam, roller rockers that are 1.6. Engine has ran with the original TPI setup but not good. I pulled the TPI to replace the factory injectors and broke the fuel rail so this is why I went non computerized.
SPONSORED LINKS
Sunday, January 8th, 2017 AT 12:50 PM
