Will not start
90,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
BOBMAC
I only start it once every couple of weeks. It takes a while and begins to fire and eventually starts. I let it sit too long in cold weather and it will not start at all now. It has a new distributor assembly. but not sure about coil. Any thoughts out there?
Dec 16, 2017 at 6:09 AM
CJ MEDEVAC
  • 11,000 POSTS
Distributor was installed after it would not run at all?
Any other changes after it quit running?
Are you 100% sure it was installed perfectly? (I can aid you!)
Can you describe how you installed it?
I guess you have used fuel or starter fluid in the carburetor to attempt to start it?
Points or electronic ignition?
Any mods that are not OEM?
The Medic
Dec 16, 2017 at 10:05 AM
BOBMAC
Distributor and coil were new about one year ago and the car has started many times afterward. I have tried starter fluid and added about five gallons of gas to make sure it would reach the engine. Sounds like I hear an electric fuel pump when I turn the key. This is my daughters car and I have inherited it for awhile and for the last year or so it has started every time eventually until now. The only real difference is colder weather and I waited four weeks to start it. I usually do it every two weeks.
Dec 17, 2017 at 5:16 AM
CJ MEDEVAC
  • 11,000 POSTS
I am kind of confused.
BOBMAC please go back to the beginning of this post and look at the information just below your username.
Jump back down here and make any corrections!
Thanks,
The Medic
Dec 17, 2017 at 10:12 AM
BOBMAC
Addressing your initial questions; The car started before the distributor was replaced. The distributor and coil were replaced by a knowledgeable person and the car ran better after they were replaced. To my knowledge this is not an electronic ignition. You must turn the key and press a jury rigged second button to crank the motor. The motor will crank now but will not start. I have tried priming the carburetor with starter fluid. I have inherited this vehicle from my daughter. That is as much as I know. It started whenever I tried until a few days ago. It has gas. It sounds like it has an electric fuel pump in the back of the car.
Dec 17, 2017 at 10:05 PM
  • 55,721 POSTS
Lets start by check for spark at the plugs. Here is a guide to help us see if the problem is fuel or spark. Check out toward the end of the guide it will show you how to check for spark. If you do the test in low light it works the best.
Please run this test and get back to us.
Cheers, Ken
Dec 18, 2017 at 6:53 AM
