Was doing work on the sunroof took the headliner out but it’s still in the open position but when I put it back on and I think the #79 relay for the sunroof/“power windows and doors” failed and somehow my actuator in my trunk latch started to move back and forth in a stuck motion and won’t stop unless I smash it shut or disconnect the wire from it but If I go to start the car the truck latch opens and doesn’t let me start. I think it’s something to do with my anti theft and the fact that my door latches don’t work why my key to enable the alarm but I can unlock them but I can use my key to enable and disable the alarm from the trunk but it won’t right now because it is moving back and forth and doesn’t disable. I also pulled out the #214 relay cause at first that one felt like it was clicking but it looked like it needed to be replaced also.
Mar 5, 2019 at 8:33 AM
