Will not start after replacing the key?
2004 TOYOTA SEQUOIA
240,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
DAVOWS
New key made, theft light goes off, but engine has no spark. Ran before new key made.
Sometimes runs for 1 second, then no spark.
No codes on scanner.
Will it throw a code for CPS by just cranking/no start?
Feb 5, 2021 at 5:20 AM
  • 110,241 POSTS
It could be the crankshaft position sensor, but it's odd that it happened after the key replacement. If you have a live data scan too, connect it and see if there is an RPM signal from the sensor while cranking. Also, take a look through this link and let me know if it mirrors what you are experiencing:
To answer your question about the code / crank sensor, there are situations that a bad sensor will not set a code. It's explained in the aforementioned link.
Also, here is a link you may find of interest:
https://www.2carpros.com/articles/stall-at-idle
Take care and God Bless,
Feb 5, 2021 at 12:07 PM
DAVOWS
Thanks!
A friend brought over a newer code reader, and it called out B2799.
Immobilizer code!
I think that we have it pinned down now!! Thank you so much for your prompt response! Cheers!
Feb 5, 2021 at 1:23 PM
  • 110,241 POSTS
You are very welcome. I'm glad you determined the problem. Please feel free to come back anytime in the future if you need help.
Feb 6, 2021 at 8:58 AM
