Won't start I just redid the head gasket?
1,500,000 MILES • 2.4L • 4WD • MANUAL
BIGTWITHDUBBLEDES
I just redid the head gasket on it and I assembled the timing marks and everything for the timing on the valves line up with the marks on the chain and on the camshaft but for some reason it won't start when I crank it over and I moved to distributor it will make like a loud crunching kind of grinding noise on one side but if I move it back together it won't make that noise and it will crank over like normal but it won't start I've had it start up a couple times but barely was running I had to pedal to the floor and still it didn't keep it running that long before it shut off I don't know why it's not wanting to start I think I lined everything up right it's a fourth time I've had to tear the engine down all the way to the timing chain can anybody please give me some insight on what it probably is and what I need to do
Nov 13, 2026 at 7:10 AM
MECHTRIX
  • 586 POSTS
Did you do all that starting at cylinder 1 tdc ? If not theres the priblem ..
Sounds like its nit timed correctly a d if it off by evan one link it won't be correct..id say get everything at tdc on cyl 1 and recheck it ..also check the distrubutir timing the same way. Good luck let us know what you find ..hope this helps
Nov 13, 2026 at 11:19 AM
MECHTRIX
  • 586 POSTS
And i might ad the crunching sound you described is definately not good somthing came loose it sounds like just take it apart and inspect it thoroughly thats all you can really do in this situation...good luck
Nov 13, 2026 at 11:24 AM
  • 55,710 POSTS
Can you please upload a video of the engine cranking so we can see what is wrong? This video can help
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Nov 13, 2026 at 4:28 PM
