Will not start
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOUG MARSDEN
Battery has full charge. When turn key at times get zero response, at times the engine will turn over. If it starts it runs rough for a second or two then shuts off. May or may not try to start at the next attempt.
Aug 22, 2019 at 3:01 AM
BMDOUBLE
  • 1,139 POSTS
You may have two different things going on, but first I would see if we can retrieve any trouble codes in the power train control module. This will give us a direction to diagnose your concern.
Aug 22, 2019 at 4:48 AM
DOUG MARSDEN
Didn't say what to do to follow the idea.
Aug 22, 2019 at 11:25 AM
BMDOUBLE
  • 1,139 POSTS
The actual codes retrieved are what will give us a direction because there are dozens of scenarios that could be possible.
Aug 26, 2019 at 4:58 AM
  • 55,732 POSTS
If I can jump in here. can I ask if the security light is flashing when it wont run?
Aug 27, 2019 at 8:19 AM
