Will not start
150,000 MILES • 2.8L • 6 CYL • 2WD • MANUAL
JACARPEN
First of all it has been running rough if you push throttle not even half way down it stalls. But I went out to start it today and it cranks over but will not start. But you can tell it wants to start. I need help. Already changed gas tank because the top of it was rusted out. And it ran good for a while and then it does this again.
Jan 21, 2018 at 2:35 AM
  • 55,743 POSTS
It sounds like the fuel pump is bad can you run this test and get back to me?
Please run this test and get back to us.
Cheers, Ken
Jan 22, 2018 at 11:36 AM
JACARPEN
The fuel pump comes on when key turns on it sounds strong I just replaced fuel pump less than 6 months ago. But now it won't start at all. Please advise. Thanks for your time
Jan 23, 2018 at 8:15 AM
  • 55,743 POSTS
It sounds like you have a crankshaft angle sensor that is out but to be sure lets run the codes to see what comes up.
Cheers, Ken
Jan 25, 2018 at 2:25 AM
