Will not run
180,000 MILES • 3.0L • 6 CYL • 2WD
PAUL YAMBRICK
Won't run like it's not getting enough fuel.
Jan 21, 2021 at 6:05 AM
BMDOUBLE
  • 1,139 POSTS
Have you tried to retrieve the powertrain control module (PCM) codes? What is the fuel pressure? or has it been checked? Let us know what tests have been run then we can go from there. This sounds like a fuel pump or the crankshaft angle sensor has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
and
Mar 2, 2021 at 4:00 AM
