Will not move when put into gear
148,789 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SLASHUGS
  • 5 POSTS
When put in gear engine would stall then torque converter was replaced. Now engine runs when in gear, but does not go forward or backward. Grinding sound when attempting to shift into park.
Nov 10, 2018 at 2:49 AM
Good afternoon.
If you hear grinding putting it into park, it sounds like the transmission is working.
Does the speedometer move up when you put it in gear?
Also, have someone look under the truck with it running and see if the driveshaft is turning.
It could be the transfer case.
Nov 10, 2018 at 5:02 AM
