Will not go in reverse
139,000 MILES • 6 CYL • 4WD • AUTOMATIC
WHITNEY827
Car drives fine but will not go in reverse unless I am on a hill.
Oct 15, 2018 at 7:26 AM
Good evening.
The fact that it goes forward fine tells me you have an internal issue for reverse application.
One thing you could try is changing the oil/filter and see if that makes any difference since reverse needs the most pressure to apply.
Oct 15, 2018 at 8:00 AM
