Crank no start
140,000 MILES • 0.6L • 6 CYL • AUTOMATIC
DOM INI QUE
Maybe someone can help me. I have had my settings computer, distributor, spark plugs and wires, alternator, computer, fuel pump and sensors changed also checked fuses. Nothing is working! Mechanic is stumped and I am at my wits end it will not start, but will turn over. However, will not stay cranked it just sputters. I have put too much money into it to just junk it. Any suggestions are welcome.
Jul 30, 2017 at 4:39 PM
CARADIODOC
  • 34,414 POSTS
First need to know the exact engine size. The different engines have very different ignition systems. Second, need to know if anyone has read and recorded the diagnostic fault codes. Disconnecting the battery will erase any codes, so if that was done when the alternator was replaced, there might not be any valid codes set yet, but check anyway. Chrysler makes doing that yourself much easier than any other manufacturer. Cycle the ignition switch from "off" to 'run" three times within five seconds without cranking the engine, leave it in "run", then watch the code numbers appear in the odometer display. Those codes never say to replace a part or that one is bad. They indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition.
If you have a four-cylinder engine, be sure to find out if it is the single overhead cam version or the double overhead cam version.
While you are gathering up this information, since I do not know how experienced your mechanic is, tell him to determine if the automatic shutdown, (ASD) relay is turning on during cranking and staying on steady. The easiest way to do that is to view its "state" on a scanner, but he can also use a test light to check for twelve volts on the dark green/orange wire at the ignition coil pack, any injector, or either smaller terminal on the back of the alternator. Knowing that will tell us where to go next.
Jul 30, 2017 at 5:58 PM
