Crank no start issue
276,999 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BPFULTZ07
It will turn over but won't start.
Jan 31, 2022 at 1:45 AM
SQM
  • 6,383 POSTS
Generally speaking, an engine will need spark, fuel and compression to start and stay running.
Can you tell me a little more of what you are experiencing?
Can you hear the fuel pump come on? Do you know if you are getting spark?
There could be a number of reasons why your engine is not running. From a bad fuel pump to faulty ignition coil etc.
Take a look at this article, it covers the typical issues:
https://www.2carpros.com/articles/car-not-running-advanced
Go through this and report back to what you find.
Let me know if you have any questions.
Jan 31, 2022 at 2:27 AM
