Won't shift into drive
170,000 MILES • 4.0L • 6 CYL • AWD • AUTOMATIC
RAMIREZ2008
My car will operate in reverse but when you put into drive it won't move and the motor dies.
Apr 1, 2016 at 12:27 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
Apr 1, 2016 at 11:44 PM
RAMIREZ2008
All I'm getting is p0562
Apr 5, 2016 at 8:15 AM
HMAC300
  • 48,601 POSTS
562 is low battery voltage so could be stored from previously but also can effect your problem. check harness at trans and tcm it may be a bad connection or something like two clutchs are operating when they shouldn't be.or it may be the internal processor inside trans. best to have a trans guy look at this.
Apr 5, 2016 at 9:15 AM
