Now hold on a minute. You said it started by push-starting it. That means you have a cranking problem. You also said you replaced parts in the ignition system, which means you had no spark. So do we have a "no crank" no start or a "cranks but wont run" no start? We have to decide if we are working on a cranking system or an ignition system problem.
One thing that can be related to both systems is the charging system. A failure there will result in the battery running down with slow cranking, and can cause the engine to stall. I think the place I would start is by testing the charging system. You can do the first part yourself with an inexpensive digital voltmeter. Measure the battery voltage with the engine off. If it is good and fully-charged, it will be 12.6 volts. If you find it is closer to 12.2 volts, it is good but discharged.
Next, measure the battery voltage again with the engine running. It must be between 13.75 and 14.75 volts. If it is low, suspect the generator or voltage regulator. If it is okay, that means it is okay to perform the second half of the tests, but that requires a professional load tester. Your mechanic will measure full-load output current and "ripple" voltage. Those will tell if one of the internal diodes is defective. With a bad diode, you will only be able to get exactly one third of the generator's rated output current. That is not enough to run the entire electrical system under all conditions. The battery will have to make up the difference until it slowly runs down over days or weeks.
Aug 7, 2016 at 12:45 PM
