Wont crank
210,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
TRU C SMITH
My truck recently quit on my while driving. It was diagnosed with a bad fuel pump. After getting my fuel pump replaced it still does not crank. The only way it will crank and run is if i pour a little gas inside the throttle body. Then it will run fine until I turn it out and it wont crank unless I repeat the same procedure. What could be the problem?
Aug 10, 2016 at 5:02 AM
SATURNTECH9
  • 30,868 POSTS
Have you checked the actual fuel pressure you have now? Also you could have a wiring issue or a bad new fuel pump.
Aug 10, 2016 at 5:17 AM
TRU C SMITH
It has a new fuel pump.
Aug 10, 2016 at 8:47 AM
SATURNTECH9
  • 30,868 POSTS
Okay and new parts can be bad right out the box. I just had a alternator right out the box with the pulley frozen up could not turn it. Can you hear the fuel pump working?
Aug 10, 2016 at 10:36 AM
TRU C SMITH
Yeah, I can hear the fuel pump come on.
Aug 10, 2016 at 2:11 PM
SATURNTECH9
  • 30,868 POSTS
So what is the actual fuel pressure? then you would see if you have injector pulse with a noid light.
Aug 10, 2016 at 2:25 PM
