Wiring diagram for the engine wiring harness needed?
200,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
BENT FENDER
Had a fuel fire burnt engine wiring harness. found a partial used harness. I am needing a wiring diagram that shows wire color and location to splice in used wire loom.
Aug 10, 2023 at 12:18 PM
  • 55,756 POSTS
Sorry to hear about the engine fire. Here are the engine wiring diagrams as requested and I have included a guide to help you test the connections.
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 11, 2023 at 4:56 AM
