Wire short / starter
120,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
ANTHONY LEE2
The vehicle starts sometimes and then sometimes it doesn't. If the wire running to the solenoid ( I'm assuming that's the correct part) is wiggled then the vehicle starts more often than not. Would that be because of that ground running to the solenoid or because the starter is shot and hire to determine the difference? Thanks in advance.
Aug 31, 2016 at 12:01 AM
HMAC300
  • 48,601 POSTS
if the wire is wiggled to solenoid then it may be a bad connection either the solenoid is bad or the connection
Aug 31, 2016 at 12:57 AM
