Starter replacement?
148,523 MILES • 6 CYL • FWD • AUTOMATIC
DOSSIE LEE
my starter makes a whining noise when it cranks.the mechanic has put 4 new starters and 2 new flywheels. i then had the old starter rebuilt and it still makes the same noise.can you please help?
Mar 7, 2010 at 10:25 AM
  • 75,988 POSTS
Hi Dossie Lee
If the crankshaft is not bent, this is common if a cheap starter is used I would suggest and AC delco unit here is a guide to help walk you through the steps with the instructions in the diagrams below to help you on your car.
Check out the diagrams (Below). Please let us know what you find.
Mar 7, 2010 at 9:13 PM
DOSSIE LEE
my mechanic had already checked the crankshaft and the starter I took the starter to a starter repair shop.the only signs of any wear was the gear that engages the flywheel they replaced it.still the same whine.he has about to give up on it when I handed him the AC delco unit worked perfect! thank you.
Mar 8, 2010 at 10:42 AM
  • 75,988 POSTS
If its the correct OEM part works every time. Good to hear, please use 2CarPros anytime we are here to help.
Mar 8, 2010 at 10:55 AM
DOSSIE LEE
we have tryed 4 new starters and 2 new flywheels .still the same noise i the took the old starter and had it rebuilt and still the same noise.can you please help.thanks.
Nov 18, 2020 at 12:10 AM (Merged)
CARADIODOC
  • 34,413 POSTS
If this is still the mounting style that uses two long bolts that go straight up through the nose into the block, add a shim. Most replacement starters come with one shim included.
caradiodoc
DEANDEGEORGE
the battery is good every thing else seems to work. when I turn the key there is nothing, no solenoid click, no nothing. I tried switching the relay/fuse under the hood and that didn't do anything.
Nov 18, 2020 at 12:11 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
DEANDEGEORGE
got it found a broke wire at solenoid thanks
2CARPRO JACK
  • 11,533 POSTS
Good find
SHARONK
I just put on a starter. the last one had a broken piece on the end. then I started the car, and guess what, this 2nd one broke! help!?
  • 110,248 POSTS
Make sure the starter is fully seated and tight. If there were shims on the original starter, make sure to use them. Finally, make sure the flywheel is tight and not damaged and the engine is free to turn.
