Wire issue after bed removal
2003 CHEVROLET SILVERADO
175,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MATT BOUCHARD
I have a the truck listed above it is a 1500. my buddy and I removed the bed to get the frame all washed up and undercoated/oiled. Also installed new tail pipes so did a bit of welding on those and some on the cab corners. And fixed up my mounted assisted back up LED lights. (Wired separately) Soon as I got the bed back on and plugged everything in, my truck has had issues with wiring/turn signals. Rapid blinking on either side, slow blinker on passenger side, fast on drivers, all lights blinking. Basically looks like a school bus all lit up. We have tried tracking down any pinched wires, tested fuses, unplugged the battery and plug back in after thirty minutes, tried replacing the circuit panel on the bed for the connectors but still have the same issues.
Apr 26, 2018 at 8:57 AM
STEVE W.
  • 15,200 POSTS
As a test run a ground wire from a clean spot on the frame to the black wire at the wiring junction block under the truck, or run it to the ground wire for either of the rear lights. Painted, oiled and cleaned could have upset the OEM grounding to the frame.
Apr 26, 2018 at 9:30 PM
