Regular drive
10,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SEAN0399
  • 8 POSTS
Hi on my k1500. I have over drive and regular drive. My question is how fast can you go in regular drive and does it save fuel? Also, is it better to use when hauling?The only time I would use regular drive would be for city and towing if I need to. Last question, we had snow about a month ago. I had it in 4h the rear end just wanted to keep breaking loose. Is their anything I can do to make the rear ending heavier so it does not slide. Sorry this is the last question the bed on my truck squeaks when I go over speed bumps or hit anything. Is their a way to quiet the bed down? Thanks.
Jan 31, 2017 at 12:17 PM
HMAC300
  • 48,601 POSTS
check mounts on bed, but you may not be able to stop squeaking. not much for sliding around that is nature of pickups when slippery out. towing use drive and overdrive when empty overdrive saves fuel.
Jan 31, 2017 at 11:33 PM
SEAN0399
  • 8 POSTS
Thanks for the help. I will look at it this weekend. As for the sliding around do you think snow tire chains.would help with the traction? thanks for all your help.
Feb 1, 2017 at 5:02 AM
CJ MEDEVAC
  • 11,000 POSTS
Two or three fellers moving/ bouncing hither and yon at specific places (all over the truck front/ back/ side and side) might give you a shot at crawling under and identifying the squeaks.
You might even be able to "inject" between rubber and metal parts using this grease gun attachment instead of replacing stuff. See link.
http://shop.advanceautoparts.com/p/plews-18-gauge-x-1-1-2-grease-injector-needle-plw05-037/22984871-P?searchTerm=grease+gun+needle
As far as weight, my Grandpa had a pile of "winter rocks" in which he would carry thru the winter in the bed of his truck. The rocks were about 50 lbs each and were place at the rear with a 2x10 board across the wheel wells.
My uncle tried to show him the EZer way by folding an old water bed in half in the back of his truck and filling it up with water, hence "loading and unloading" was not back breaking! Grandpa was an old dog, new tricks didn't cut it for him!
Chains do work well, knowing how to keep 'em on is the trick. I found that the type that have 2 cable sides and steel rungs/ cross members (the whole system resembles a rope ladder) seem to latch on and stay tight as well as they are a whole lot less noisy. EZer than installing chains. They store a lot better and weigh nearly nothing.
The Medic
Feb 1, 2017 at 9:51 AM
HMAC300
  • 48,601 POSTS
snow chains are good for snow but on pavement can be worse than what you havenow.
Feb 2, 2017 at 11:03 PM
