2005 Chevy Silverado heat from cab to bed
2005 CHEVROLET SILVERADO
HYDRO
is there a way to connect the vents on the out side of a chevy
crew cab pick 05 ? to run heat to the bed? i put a ARE cap on it. like to keep my dog warm.
i was thinking of cutting holes in the bed run flex to the vents ? it looks like thre just ruber covering the vents on the back of cab.
Oct 28, 2009 at 8:01 AM
QUAGMIRE86
  • 98 POSTS
That seems like it would be alot of work and fabrication. I, personally, would go the route of installing a powered outlet in the box area and buying/using a (fused) ceramic heater with a fan. Wire the the outlet on a circuit that only works when the truck is on (ignition circuit). But you have to pay attention to current rating of said heater and any circuit you apply it to.
Or, just buy som seat covers and let the pooch ride up front with you.
Oct 29, 2009 at 3:36 PM
