Window binding on the way down
190,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
DCKELLEY
  • 125 POSTS
both my front windows on my car are binding. i started working on the drivers side by lubing it. now it goes up great but binds in one spot going down. if i help it just a little it goes down fine. i haven't taken the door panel off yet.
I'm thinking it may need to be lubed inside. just thought i'd check with you all first. thanks, Don
Feb 21, 2019 at 5:41 AM
DCKELLEY
  • 125 POSTS
after lubing it works great!
Feb 22, 2019 at 8:23 AM
  • 55,616 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Feb 23, 2019 at 4:54 AM
DANIEL DAILEY
  • 13 POSTS
Went to put down drivers side window down. heard a pop and know the window leans forward and cant put window down. i did get it to roll up. what is wrong? Dan Dailey
Feb 23, 2019 at 4:54 AM (Merged)
window regulator has failed and needs to be replaced.
BUGGZI
Electrical problem
1998 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 98.450 miles
I have power window's, everytime there is moisture, rain, snow or dew they don't want to open. I can play with the switch to make it go down about 2 inches, then back up a few time, and sometime's it will open. What should I look at to fix this probelm?
WRENCHTECH
  • 20,760 POSTS
The circuit would have to be tested to know for sure but your probably looking at a bad motor. In this car the motor comes with the regulator also.
