Will not start or run when engine warms up
107,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
WILBUR JOYNER
When cold engine will start, after running a very small amount and stopping the engine, the starter will turn the engine strongly, with absolutely no attempt at starting. After letting it sit for a while, sometimes longer, it usually. Starts just as quick as it is stopped, no restart for a while.
Sep 28, 2018 at 11:07 PM
Good morning.
When it does not start, have you checked for spark and if you hear the fuel pump coming on?
One of them is missing if it will not run.
I would check the fuel pressure when it will not start and also check for spark to the plugs.
Sep 28, 2018 at 11:46 PM
