will not start, no sound at all
96,000 MILES
NATEPUTT
I came out one morning to start my car and nothing happened. So I tried to jump.start the car nothing happened. Not a sound.. the car isnt try to crank.over at all.. but the lights. radio and stuff like.that work perfectly fine. I checked the starting relay that is good. And the fuse under the dashboard under.the driver side label starter.. everything seems fine with the battery system. What esle am I missing?.. thank you
Sep 2, 2013 at 1:18 PM
SATURNTECH9
  • 30,868 POSTS
Do you have a multi meter to do some testing?
Sep 2, 2013 at 1:31 PM
NATEPUTT
Sorry I do not
Sep 2, 2013 at 1:34 PM
  • 55,766 POSTS
When you try and crank the car over with the headlights on do they go dim?
Sep 2, 2013 at 1:44 PM
NATEPUTT
The lights turn off when key is turned to start
Sep 2, 2013 at 1:48 PM
SATURNTECH9
  • 30,868 POSTS
With a multi meter we could test to see what the battery reads while trying to start it.Also what the small trigger wire at the starter reads while trying to start it?Also what the main battery cable at the starter reads while trying to start it?
Sep 2, 2013 at 1:51 PM
