Will not start
194,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
PERFECTION51295
Timing belt broke, replaced it, now backfires. tries to start but never starts.
Dec 8, 2017 at 1:08 PM
WRENCHTECH
  • 20,760 POSTS
This engine very rarely survives a broken timing belt. It is an interference engine so the second the belt brakes, the pistons hit the valves and bend them. A leak down test with answer that, but you are likely looking at a new engine if that is the case.
Dec 9, 2017 at 8:22 AM
PERFECTION51295
No way to replace valves?
Dec 9, 2017 at 8:45 AM
WRENCHTECH
  • 20,760 POSTS
Not with 194,000 miles on it. The lower end is too far worn out and would not handle the pressure of the top end being rebuilt. A used engine would be your smartest move once you confirm the valve problem.
Dec 9, 2017 at 8:48 AM
PERFECTION51295
What if I just replace the couple that are bent?
Dec 9, 2017 at 9:09 AM
PERFECTION51295
I really cannot afford new engine.
Dec 9, 2017 at 9:11 AM
WRENCHTECH
  • 20,760 POSTS
Unfortunately it does not work that way. First of all there may be piston damage from the impact. The valve seats and valve guides are going to have a lot of wear so a new valve just is not going to mate up to the head without a lot of machine work first. You cannot machine only some cylinders. There just is not any way to do a patch job.
Dec 9, 2017 at 9:14 AM
