Will crank but does not start
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
LUPITA58
I recently changed the fuel pump and battery because it was cranking up but it wasn't starting. It was good for about 4 days and then it did the same thing. It would just crank but it doesn't start. I started messing with the fuse box I noticed that once I unplugged and re-plugged the crank, ignition and fuel pump fuse sometimes it helps and it will start. So I was wondering if maybe it was the fuse box that's going bad or electric problems.
Aug 22, 2019 at 3:29 PM
Good morning,
Yes, it could be the fuse box. Clean the terminals that the fuse locks into.
If you have a test light or voltmeter, test the voltage at that fuse with the key on.
Aug 22, 2019 at 7:36 PM
