The OD light flashing normally means we have an internal issue. However, the fact that we have a check engine light as well means we need to start with checking for codes.
Once we know what codes are there, we will have a better idea, but we also need to check the fluid and find out if this is low, discolored, or smells burnt.
Here is a guide that will help with this as well:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
I expect to see a code for the torque converter clutch solenoid and if there is then we can dig into that but that would be the likely cause.
Let us know what you find with this, and we can go from there.
Thanks
Jun 11, 2022 at 1:26 PM
