Engine shutting down while driving
327 MILES
BENNY BRIDGES
While driving the motor just stops the whole car stops, I put in neutral and it starts right back up. What is causing this?
Dec 2, 2019 at 3:27 AM
CJ MEDEVAC
  • 11,000 POSTS
1995?
Long time.
Ever change the fuel filter?
If it spits and sputters a bit before it dies (starving for fuel) that could be it. Once stopped, trash/ debris falls away from the restricted line and it will re-crank. Runs once more until the trash gets sucked in again.
Another possibility.
Do you notice hitting bumps or making left or right turns that makes it die?
The Medic
Dec 2, 2019 at 11:21 AM
