So at first my truck wouldn't start one day. It wouldn't crank, the fuel pump wasn't engaging, but I had power to the radio and stuff. I found out my PCM was fried. I then ordered a flashed board and Installed the new one. It then fired right up with no problems but showed me a code for transmission gears second and fourth. I didn't drive it or anything at this time so I had my mechanic come to my house and change the solenoid pack to fix the code. Well after I got the check engine light to go away I thought it was good to drive. So I started it up and drove maybe three to five miles to a gas station. When I got to the gas station I shut it off and when I went to start the truck back up I had the same issue again. Where the ignition side was not working. The new board had friend on me again. I then had it towed to a mechanic that was supposed to be a family friend. He then told me the board was no good just like I told him. He wanted me to get another board so he could fix it and get it going. I got the new board in the mail brought it to him and explained that something has to be wrong that's shorting out my board and to not just start it and think it's fixed. Well that's exactly what he did. So now three boards later he tells me the boards I got were bad. So I then got O'Reillys and get a board from them and bring it to him. Well now that he has installed it he says it's showing automatic shutdown relay on his computer and can't find the issue or doesn't know where to look. I have been dealing with this for a year now and really would like to just get it figured out. I'm going to go tow it from his shop to my house and attempt to tackle this on my own. I have meters, tools, and knowledge about circuitry. I don't know where to look or where to begin to look though. I do know that before this all happened I had these following things happening from time to time -
My radio would sometimes not come on when I started the truck so I would have to shut it off and turn it back on to get it to work.
My rear stereo speaker would make a popping noise when I was driving and hitting bumps.
I had to give it gas when I started it sometimes cause it would lag a bit and the truck was fuel injected.
One morning when I went to start the truck it would click and not fire up and I would have to turn ignition all the way back and try again.
Now when the board fried I had no power to the fuel pump or gas gauge but I had power to my lights and my radio.
Any information would be so much help guys thank you!
Jan 9, 2019 at 1:19 AM
