My dakota when the moisture level is high like when it rains quite a bit the speedometer will jump up and down between 10 mph to 120 mph,and the transmission will jump in and out killing the motor.the engine light will come on for a while, off a while wet or dry outside.I've allready change the speed sensors on both the transmission and the rear end.could this be a bad PCM?
Feb 2, 2010 at 12:13 PM
