Why is there white smoke when I first start my car?
28,000 MILES • 3.5L • 6 CYL • TURBO • 4WD • AUTOMATIC
AUGIS DONELAITIS
Hello, when i start my car white smoke comes from exhaust for 10 15 seconds and after disappears, is it normal?
Aug 9, 2022 at 11:00 AM
  • 110,248 POSTS
In most cases, that is normal. What happens is condensation builds up in the exhaust system as it cools. When you start it, the heat turns the condensation into steam.
The only other thing would be if engine coolant is getting into the combustion chamber. But that usually will last longer and be a very thick white smoke.
Do me a favor. First, confirm the engine coolant isn't low. If it appears low, when you see the smoke from the exhaust, confirm it doesn't have a sweat smell to it.
Let me know what you find.
Aug 9, 2022 at 12:33 PM
AUGIS DONELAITIS
Hello Joe, thanks for your reply, the coolant level stays normal, a bit higher when engine is warm, the smell is normal. It starts when I'm starting the car, after 10-15 seconds it disappears.
Aug 9, 2022 at 10:15 PM
  • 110,248 POSTS
Everything you mentioned points to simple condensation burning off in the exhaust. That is absolutely nothing to worry about and is normal.
If anything changes, let me know.
Take care and please feel free to come back anytime in the future.
Aug 10, 2022 at 4:12 AM
