Which oil conventional or full synthetic
200,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JPARRA602
  • 9 POSTS
My car just hit 200,000 miles on it. Which oil should I really be using? Conventional or full synthetic? And any recommendation on which brand to use?
Jan 31, 2019 at 7:08 AM
  • 110,248 POSTS
Hi and thanks for using 2carpros.com
I would continue using what you have been using. As far as full synthetic, I have seen people switch to it after years of using conventional and the engine develop leaks.
With that in mind, use what the manufacturer recommended when it was built. Use a conventional 5w30 unless you are in temps under -20 degrees F Here is what is recommended:
Engine Oil
API Classification .................... Look for Starburst Symbol
Above -18° C (0° F) .................... 10W-30, 5W-30 (preferred)
Below -29° C (-20° F) .................... 5W-30 synthetic (preferred) , 0W-30
Jan 31, 2019 at 10:35 AM
JPARRA602
  • 9 POSTS
I’ve been using full synthetic oil but recently I have noticed that i’m also losing oil. I don’t have any leaks, no wet spots on my driveway so I think my engine is burning it up. Should I switch to conventional oil?
Jan 31, 2019 at 12:22 PM
  • 110,248 POSTS
Welcome back:
You could try it to see if it slows things down. Keep in mind, with the mileage on it, one can expect oil consumption to a certain degree. I don't know how fast it is going through it, but a quart every 1K miles at this point would be acceptable. I don't know where you are located, but if you are in warmer temps, you may even want to try 10w30.
Jan 31, 2019 at 12:33 PM
JPARRA602
  • 9 POSTS
I honestly don’t know how fast it is burning through the oil. I just randomly check. And yes I live in Phoenix, AZ the weather reaches 115 degrees outside during the summer. If I switch to 10W-30 should I use synthetic or conventional? And is it honestly safe to switch to 10W-30 after using 5W- 30?
Jan 31, 2019 at 12:59 PM
  • 110,248 POSTS
Since you have used synthetic, stick with it. However, it won't hurt if you change. As far as the oil weight, 10w30 is one of the options given, so it is fine to use.
Jan 31, 2019 at 1:26 PM
JPARRA602
  • 9 POSTS
Okay, so on my next oil change I am switching to Castrol GTX high mileage synthetic blend 10w30. Do you think that’s a good choice?
Jan 31, 2019 at 3:09 PM
  • 110,248 POSTS
Honestly, I think it's a great choice. You're getting the best of both worlds. Let me know if it helps with the oil consumption.
Feb 1, 2019 at 4:52 AM
