Coolant temperature sensor location
MOELLG
  • 2008 FORD FUSION
  • 3.0L
  • V6
  • AWD
  • 140,000 MILES
Need to know where temperature sensor is located v6 duratech?
Wednesday, July 12th, 2017 AT 8:34 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,628 POSTS
The sensor is located near the front of the engine on a coolant hose fitting. Here is a diagrams for both engines, (below) and a guide that will walk you through the steps of changing the coolant temperature sensor.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Wednesday, July 12th, 2017 AT 4:05 PM
DOCFIXIT
  • 18,828 POSTS
It is located on rear of engine on the thermostat housing. Follow top radiator hose to thermostat housing to find the sensor.
Wednesday, July 12th, 2017 AT 9:10 PM (Merged)
JAMIEJONES
  • 2006 FORD FUSION
  • 96,000 MILES
Where is the engine/coolant temperature sensor located?
HMAC300
  • 48,601 POSTS
It is located near the thermostat housing at the upper radiator hose near the engine.
Here is a diagram below.
Please let us know happens so it will help others.
MICHAEL MONTANEZ
  • 2007 FORD FUSION
  • 4 CYL
  • FWD
  • 110,000 MILES
Where is the coolant temperature sensor located on my car?
HMAC300
  • 48,601 POSTS
See picture marked with an arrow.
TMUCHMORE7
  • 2006 FORD FUSION
  • 176,000 MILES
Where is the coolant temperature sensor located?
Thursday, December 27th, 2018 AT 9:19 PM (Merged)
  • 31,937 POSTS
Here is a guide to help walk you through the steps of the repair with instructions and locations for both engine in the diagrams below.
