Coolant leak
134,000 MILES • 3.0L • V6 • AWD • AUTOMATIC
MOELLG
  • 6 POSTS
Coolant dripping onto exhaust pipe under firewall. any problem areas in this location or thoughts on this matter? thanks
Jul 14, 2017 at 3:40 AM
SATURNTECH9
  • 30,869 POSTS
A heater hose or the heater core is there any coolant inside the car on the front floor board? The best thing to do is try to rent a coolant pressure tester at a auto parts store like auto zone and pressure test the system and look for leaks that way.
Jul 14, 2017 at 6:07 AM
MOELLG
  • 6 POSTS
Not heater hose or core appears to be coming from head gasket or freeze plug need to inspect with mirror.
Jul 15, 2017 at 4:27 AM
SATURNTECH9
  • 30,869 POSTS
They rent inspection cameras at auto zone I would rent one to have a better look.
Jul 15, 2017 at 6:55 AM
MOELLG
  • 6 POSTS
Thanx for response car had overheated several times due to faulty fan module before it was brought to me i suspect engine is all alloy and may have a cracked head or gasket will do further inspection
Jul 17, 2017 at 11:47 AM
SATURNTECH9
  • 30,869 POSTS
Alright keep me posted.
Jul 17, 2017 at 12:15 PM
