Clicking sound when in gear, why?
197,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
LEOBARDO MENDOZA
When in gear there's a clinging sound, why?
May 4, 2023 at 1:34 AM
  • 55,688 POSTS
This sounds like the driveshaft U joints need to be replaced, but to be sure get a flashlight and inspect the U joints for rust colored dust at the joint this is a sure sign the U joint is worn out. Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. You can remove the driveshaft. Here is a guide to help and I have left instructions in the images below on how to remove the driveshaft for inspection:
https://www.2carpros.com/articles/comprehensive-guide-to-checking-and-replacing-an-automotive-drive-shaft-u-joint
and
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 4, 2023 at 10:53 AM
