When should I change the timing belt
46,200 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
MUSICOLLECTOR
  • 15 POSTS
Some people say I need to change it around 42,000 miles and some say around 60,000. Who is right? I would like to drive it as long as possible without changing it. As you can see, I hardly drive it.
Thanks in advance.
Harry
Oct 24, 2016 at 7:31 AM
MUSICOLLECTOR
  • 15 POSTS
Also, can it be examined visually for flaws or cracks?
Oct 24, 2016 at 7:33 AM
WRENCHTECH
  • 20,758 POSTS
The one thing I can tell you is that with this engine a timing belt failure will mean a new engine so the maintenance is rather important.
Here is the official recommendation of the manufacturer.
{34} On 2005 and prior years, under normal conditions, inspect water pump and replace timing belt at intervals of 105,000 miles or every 84 months. On 2006-10 models, under normal conditions, inspect water pump and replace timing belt at maintenance minder symbol 4. On all models, if vehicle is operated at ambient temperatures under -20 F or ambient temperatures above 110 F, inspect water pump and replace timing belt at intervals of 60,000 miles.
Oct 24, 2016 at 9:07 AM
