Steering wheel suddenly went out alignment with horrible noise on front right wheel
2006 KIA SPECTRA
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
DPOUND9812
I'm a diyer and work on cars a bit. I haven't had a chance to jack this car up yet, but I've never encountered a problem like this before. My fiancee was driving, and out of nowhere after a not sharp at all turn her cars steering wheel went severely out of alignment, and every time she brakes it straightens out as well as making a horrible pop when the brakes are applied from the front passenger side wheel. Before this happened she was having moderate wheel shake at lower speeds that lightened up as the car moved faster.
Aug 13, 2019 at 10:20 PM
DPOUND9812
This has been solved. I jacked it up and the frame where the control arm mounts rusted and snapped. Car is probably totaled.
Aug 14, 2019 at 1:03 AM
RENEE L
  • 1,260 POSTS
Hello DPOUND9812,
Thank you following up with what you found. So sorry it was something that expensive.
Thank you for visiting 2CarPros.
Kind regards,
Renee
Admin
Aug 14, 2019 at 4:25 AM
