2008 Kia Spectra How to remove tires with sensors
2008 KIA SPECTRA
KING 1
Tires and Wheels problem
2008 Kia Spectra 4 cyl Two Wheel Drive Manual
One tire is losing air want to remove and repair without damaging sensor.[img:c4213e97c8]http://www.2carpros.com/forum/automotive_pictures/381779_P7030495_1.jpg[/img:c4213e97c8]
The car belongs to a friend.
Jul 13, 2009 at 9:12 AM
  • 110,240 POSTS
The sensor is part of the valve stem and will not be damaged when you remove the tire. However, I don't recommend using a tire sealant. Have you been able to locate the leak? If not, try this.
Take a spray bottle, add some dishwashing soap and water together in it. Spray the tire all over with the solution. If there is a leak, it will bubble where the leak is located. If the leak is in the tread area, just plug it. If along the wheel bead, you will need to remove the tire, clean the wheel, and they actually make a sealant for this purpose that can be applied. If the sidewall of the tire has been punctured, do not plug it. The plug will not hold on the sidewall. Have it checked by a tire shop to see if they can patch it from inside or if the tire needs to be replaced.
Oct 14, 2009 at 1:14 AM
