Steering Wheel shaking
155,000 MILES • 4 CYL • AWD • AUTOMATIC
BRITTNESS
until today it was driving perfectly. The past two days the weather has been non stop heavy rain, sleet and wind which I have had to drive quite a bit in. Today while on highway my wheels began shaking and felt slight tugging of car. Wheel does not shake under sixty mph. Also, noticed my hubcaps are no longer lined up with the tires as they were and should be. Could the weather have caused this?
Apr 1, 2017 at 10:54 AM
  • 55,616 POSTS
This is a class tire balance problem, I would start by rotating the tires front to back to see if it helps.
here is a guide that will help you as well.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Best, Ken
Apr 3, 2017 at 1:02 PM
