1997 Honda Accord steering wheel shakes
GSUP0505
  • 1997 HONDA ACCORD
Suspension problem
1997 Honda Accord 4 cyl Two Wheel Drive 160000 miles
i was in an accident a while back it ben repaired but for some reason whenever I driving above 35mph my steering wheel shakes and so does the front end. Do you have any idea what might cause this?
Saturday, January 10th, 2009 AT 11:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
A few different things can cause vibrating in the steering wheel.
What all was replaced/damaged in accident?
It may be worn ball joints or wheel bearings. These components are used to hold the wheel straight up and down, if they start to fail they will cause vibrations and usually sounds will be accompanied as well.
If there are no unusual sounds, it could just need a wheel alignment or one of the tires has lost its wheel balance.
You can have a wheel alignment shop check the tires for proper balancing and align the front end. This usually costs around $50.
Saturday, January 10th, 2009 AT 11:25 PM
