1999 Honda Accord Shakes over 60 MPH
JOSEPHGUTTO
  • 1999 HONDA ACCORD
  • 4 CYL
  • 125,000 MILES
My 1999 Honda Accord just had a tire alignment. I had this done because when I get the car over 60 MPH I can feel the steering wheel shake slightly and you can feel it a little in the passenger seat as well. I have a crack in the boot of my Left CV joint. This has been doing this about 8 months now. It has not gotten any worse. When I hit bumps I hear a clunck sound. I was wondering if that could be because the CV joint no longer has grease in it and that could be causing it? Thank You.
Thursday, February 28th, 2008 AT 10:25 AM
MASTERTECHTIM
  • 4,749 POSTS
Does it make a clicking sound when making hard turns in a parking lot? The vibration is most likely a wheel balancing problem, not alignment. Try balance then get back to us
Thursday, February 28th, 2008 AT 11:32 AM
JOSEPHGUTTO
The car does not click at all when turning or anytime. Whenever I hit a bump I hear a light clunk sound. If it’s a light bump and light clunk. A hard bump a hard clunk.I have had the tires rotated and balanced about 3000 miles ago. The tires are about a year old but are pretty worn. Whenever I hit a bump though I get a clunk sound...
Thursday, February 28th, 2008 AT 11:48 AM
MASTERTECHTIM
  • 4,749 POSTS
The alignment probably will fix the wearing problem. Click noise over a bump sounds like its probably the sway bar end links. Very common. Again tires are probably the shaking.
Thursday, February 28th, 2008 AT 12:00 PM
JOSEPHGUTTO
Thank You.
Thursday, February 28th, 2008 AT 2:34 PM
