Does this truck have wheel cylinders on the front two wheels?
215,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
STRUMBLY
i just want to know if my truck has wheel cylinders on the front 2 wheels.
Jun 11, 2024 at 7:30 AM
CARADIODOC
  • 34,414 POSTS
Nope. Those are used on drum brakes. Drum brakes were used on the front wheels through most of the 1960s, but by around 1969 to the early '70s, everyone went to disc brakes on the front. Disc brakes require more pedal effort to get the same stopping power, so most models added power brakes. Drum brakes are still used on the rear, but even there, a lot of models have gone to disc brakes on the rear because they respond better when used in optional anti-lock braking systems.
You have disc brakes on the front. They use brake calipers. Given the age of your truck, it's a pretty good bet you have drum brakes on the rear, but if disc brakes were an option, you have to look to see which you have. Calipers are plainly visible from behind the wheel, and often through holes in the wheel. They will look similar on the rear. If you have drum brakes on the rear, you can't see the wheel cylinders without removing the wheel and brake drum. To tell which type you have, you don't have to go through all that. If you don't see a caliper, you have drum brakes.
Jun 11, 2024 at 11:20 AM
STRUMBLY
Thanks a lot, for tha info. I just couldn't remember if my 2000 had m on tha front er not. Looks like I'll be rebuilding a caliper instead. Thanks again.
Jun 12, 2024 at 12:50 AM
