Intermittent will not start, battery draining?
150,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
LILCASS
I put two new alternators and a battery in my car. Sometimes my car will start sometimes it won't, but something seems to be draining my battery, what is it?
Aug 3, 2022 at 7:34 PM
SQM
  • 6,383 POSTS
Does the battery drain when the engine is running or when the car sits overnight?
When does not start, are you able to jump start it?
So, when the engine runs what is the voltage output to the battery?
The alternator should have 13.6V to 15.2V output to the battery.
If the battery drains overnight then you have an excessive parasitic drain, which could be due to any number of electrical components staying on or malfunctioning. Like a glove box light staying on or a shorted window switch.
Let me know a bit more about what you have been experiencing.
Aug 4, 2022 at 12:58 AM
