What size serpentine belt to bypass AC compressor
96,000 MILES • V6 • RWD • AUTOMATIC
CODYGAMBIT
Was trying to bypass AC compressor but was not sure if the size as the auto does not carry one like that for this model. I would measure it with a string but this model and year is in a tough position, and was trying to see if someone knew the size to make it a bit easier.
Aug 29, 2017 at 1:50 PM
WRENCHTECH
  • 20,758 POSTS
Engine size?
Aug 30, 2017 at 3:27 AM
CODYGAMBIT
3.0 L-4V V6 engine.
Aug 30, 2017 at 3:57 AM
WRENCHTECH
  • 20,758 POSTS
Unfortunately you cannot simply use a shorter belt on this. The path of the belt would contact the tension-er and the stretch without a pulley would be too long and the belt would vibrate even if it could clear the pulley. You have to maintain a compressor with at least a working pulley.
Aug 30, 2017 at 4:06 AM
CODYGAMBIT
Aug 30, 2017 at 4:38 AM
WRENCHTECH
  • 20,758 POSTS
You are welcome.
Aug 30, 2017 at 4:39 AM
