Drive belt
80,000 MILES • 3.9L • V8 • RWD • AUTOMATIC
MARCUS MANNING
Cannot find a step by step tutorial on how to install a serpentine belt for my car listed above. The belt that the mechanic installed came right off and my car runs exclusively off the battery.
Mar 5, 2017 at 2:15 AM
CARADIODOC
  • 34,414 POSTS
This is considered too basic to bother with a video. There should be a belt routing diagram on a sticker on the engine or somewhere under the hood. If the belt popped off, there is a reason that happened. That has to be addressed first. There is a spring-loaded tension-er pulley that could be weak. More commonly one of the pulleys is tipped, turned, misaligned, or wobbling due to worn bearings. Usually you can identify which one is causing the trouble by wiggling them by hand.
Mar 5, 2017 at 4:30 AM
