Which side of the engine is bank one?
2001 LINCOLN LS
130,000 MILES • V8 • 2WD • AUTOMATIC
MANNY4201
  • 8 POSTS
I Checked the engine computer and it said it is running rich,also my oxygen sensor,bank 2,section 1 is bad.My question is :does the bad oxygen sensor make the engine run rich? And which side is bank 2 and which one is section 1?
it is a Lincoln LS,2001 with 3.9 V8 engine,130000 miles.A reponse will be very much appreciated.Thank you.
Manny
Sep 17, 2009 at 3:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, a faulty O2 sensor can cause lean & rich fuel issues..the passenger side of the engine is the bank 2. section 1 will be the sensor located before the catayltic converter.
Sep 17, 2009 at 3:27 PM
MANNY4201
  • 8 POSTS
Thank you very much bluelightnin6,also I'm a little confused now,auto zone tell me that bank 2 is on the driver side,what you think?
Manny
Sep 17, 2009 at 4:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Passengers side will be bank 1.. Whichever side of engine that cylinder 1 is located on is bank 1, other side is bank 2. Diagram below shows that your vehicle's cylinder 1 is located the passenger side.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_989.jpg
Sep 17, 2009 at 4:42 PM
MANNY4201
  • 8 POSTS
Thanks again,looking at diagram #1 cylinder is on the right(passage side)I'm confused. Manny
Sep 18, 2009 at 3:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
So sorry about that, the arrow had me confused haha. You are correct, it is passenger side .
Sep 18, 2009 at 3:55 AM
MANNY4201
  • 8 POSTS
Hello bluelightnin6,and thanks again,diagram of engine show piston #1 on passage site,so what now,I'm confused.
Manny
Sep 18, 2009 at 3:56 AM
