What oil stabilizer
194,700 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PLUXO
  • 71 POSTS
I have a bad engine bearing that was causing my oil light to flicker. Mechanic said bad engine bearing is causing low oil pressure and that I needed thicker oil, so he added Lucas oil thickener. Problem is, I'm at the store and I am not sure what thickener to use. Lucas Heavy Duty or Lucas Synthetic. Please send me your thoughts on the situation and what to use.
Apr 14, 2019 at 3:41 AM
SCGRANTURISMO
  • 4,897 POSTS
Are you running synthetic oil? If so, I would get the Lucas Synthetic. If not, I would get the Heavy Duty. Please, if you have any other automotive questions, please feel free to ask. That's what we are here for.
Thanks,
Alex
2CarPros
Apr 14, 2019 at 6:40 AM
